Alternator
poddack
Re: Alternator
Post by poddack »
how's your accessory belt, crank pulley, tensioner........
Hmmmm, straight 6 goodness!
Blue2
Re: Alternator
Post by Blue2 »
All been recently replaced, but thanks for the thought. The thing is I don't have a charging problem, it's just coming up on the display that it's not charging and the battery light is lit on the dash, Hope the rain holds off tomorrow so I can have a good check around. Cheers
Blue2
Re: Alternator
Post by Blue2 »
Well I've checked with a multi meter and it's charging a @ 14.42 so there's no problem with the charging side of things, just the problem with the battery light on the dash????
