Non Starting HDI-90HP
TJD
Post by TJD »
Hello All!
My Problem,
Began to have a difficult starting hot or cold. The engine sometimes would not start for perhaps 9 or 10 turns. I'd switch off the ignition, try again and 3 or 4 turns it would start.
This problem got more and more frequent and a warning light started to light on the dash at the same time, the symbol is a square with a key inserted. I am told this is a immobiliser fault warning light.
I also noticed that each time this light came on, the the tank pump wasn't working, I eliminated (I think!) the pump as the cause by connecting a spare pump I have (which I tested before trying) this pump also doesn't work on the car when trying to start.
The car has finally refused to start at all!
I have since changed the barrel mounted transponder aerial as I understand this can be a source of problems, still no go!
Does anyone have any advice on where to look next or what to do.
Is it possible that faulty or worn contacts in the ignition switch could be the cause? (the car has done 200,000 miles)and am I right in thinking there is no point in obtaining another key (I don't have a spare)
This posting is also in Electrical System Talk Forum.
Thanks in advance
Tony.
Are you getting power to the pump? Immoboliser can be a cause, but you say it starts (or rather it did) after 10 turns, which sort of eliminates that (it wouldn't start at all otherwise!). Could be glow plugs not pre-heating diesel....
turbolag
Officer of the law!
Post by turbolag »
The symptoms sound more like kacked glow plugs (rare on an HDi) or a diesel filter that needs bleeding/replacing, though the warning light and pump symptoms would contradict this....?
