I've set to work and already done:
2 oil changes and an engine flush
All filters
Coolant flush and new coolant
Timing belt kit (belt was 20k overdue ^^)
Water pump
Accessory belt and tensioners.....gawd that tensioner spring is a bugger!
New cam cover gasket
Resoldered dry solder joints on instrument cluster (speedo was a bit erratic)
Stripped out the interior, cleaned it and rebuilt (last owner had dogs :p)....nice and Alpine fresh now
.....still to do:
Rear suspension wishbone bushes, not looking forward to this.
Trackrod ends
Rear ARB bushes, not looking forward to this either, especially the one on the fuel filler side!
Rear drop links, done one already, had to cut the nuts off!
Rear link bars
.....then get 4 new tyres on it and booked in for a 4 wheel alignment
She's burning 100% WVO and running like a champ
It does have some rot on the sills unfortunately. I can't seem to find sills anywhere
