407
- 2.0 Turbo
407
just aquired a 407 hdi with a blown engine, now i have a 52 plate 2.0 110 hdi with smashed rear end would the engine transplantfrom the 406 int othe 407 to make one good car i think the only stumbling block would be the 407s 6 speed box
- highlander
- PowerFlow Shill
Re: 407
I would think that if the engine in the 406 and the engine in the 407 are the same, you would be able to use the 407's 6-speed box. If not, then you could always take the 5-speed box out of the 406 as well as the engine?
Re: 407
I don't think there were engine variants common to both 406 & 407, (but I could be wrong).
I don't think there's any issue mating a DW10 to an ML6 gearbox, but we don't know waht the original engine was - could be a 1.6 HDi, in which case there may be problems.
The greater concern is probably getting the electronics to work - can't see a 406 engine ecu working in a 407, or an older engine working off a newer ecu.
- highlander
- PowerFlow Shill
Re: 407
I thought the 2.2 HDi was present in both cars (or was that the 406 and the 607 only?) and so I figured that the 110 HDi might have appeared in both as well.
Oh well. I'll butt out as I really don't know enough to be advising on this sort of thing - I completely forgot about the ECU
Hope this works out for you!
- rwb
Re: 407
Just what is the difference between a 2.0 110 and a 2.0 136?
- Bailes1992
Re: 407
2.0 HDi 136 is a Ford lump
The 2.0 HDi from the 406 won't fit.
The 1.6 is a no no.
Although I think the 2.2 might be a go but you'd have to swap most the ancilaries, injectors etc etc
The 1.6 is a no no.
Re: 407
Bailes1992 wrote:2.0 HDi 136 is a Ford lump
The 1.6 is a no no.
The 2.0 136 is fitted to Ford mondeo, widely renowned as a huge improvement over Ford engines, it is also fitted to many of the Volvos amongst several others.
The layout under the bonnet along with the different subframe is completely different on the 407 to the 406.
Dogslife is probably correct about the electronics compatibility.
- 2.0 Turbo
Re: 407
407 is a 2-0 136 on 08 plate in zenith spec if all else fails i could break it for spares
Re: 407
My apologies, the 140 bhp came in september 2008.john170277 wrote:407 is a 2-0 136 on 08 plate in zenith spec
Here is a list of specs.....http://www.parkers.co.uk/cars/specs/Sum ... model=1212
Re: 407
Just a wild suggestion, but if the original engine's got a bottom end problem, might it be possible to graft the 136 head onto the 110 block?
- 2.0 Turbo
Re: 407
its not a bad idea i will ask at the local specialists to see what knowledge they have
- rwb
Re: 407
oh yeah, I remember nowjasper5 wrote:the 110 is 8 valve and the 136 is 16 valve
I thought it was just the 110 with a 16 valve head and a few minor tweaks?Bailes1992 wrote:2.0 HDi 136 is a Ford lump
What do Ford call it? TDCI?
That would be cooldogslife wrote:if the original engine's got a bottom end problem, might it be possible to graft the 136 head onto the 110 block?
But I would imagine that 1.6 110, 2.0 136, Mondeo and 407 have mutually compatible engine mounting points, but that 2.0 110, 406 is different to this.
