changing feul filter 110 hdi
hi all i have no manual yet for my 51 plate hdi ,do i need any tools and how do i do it? thanks in advance
- 2.0 Turbo
Re: changing feul filter 110 hdi
there are 2 different kinds of filter housing one is a twist lock and i think the other is bolted
if you have the twist lock housing make sure you tighted well or you will have high pressure fuel all over the engine
If you have the twist one, which I believe is Bosch, then use a spanner and don't be tempted to actually twist it off as chances are, you'll snap one of the fuel pipes off the top
Use a magnet as well to clear any metal particles out of the housing
1999 D8.5 HDi GLX - Sold
Bring back my 406
