Limp mode ... Please help.
mattyf
Post by mattyf »
Hey all. After the trouble I was having with my coolant now I have a problem .... Limp mode ....
Is anyone near lymington / New Milton that has a code reader, or could someone point me in the right direction to buy one?!
Many thanks
Matt
Harshan
2.2 16v
Re: Limp mode ... Please help.
Post by Harshan »
I bought a PP2000 from ebay for about 200USD
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
mattyf
Post by mattyf »
Thanks mate, I've been looking at some of the cheaper ones on e-bay. Dose anyone have any experiances of them?
Also I work in southampton if some one could help and read the codes for me??
Harshan
2.2 16v
Post by Harshan »
mattyf wrote:Thanks mate, I've been looking at some of the cheaper ones on e-bay. Dose anyone have any experiances of them?
In fact I was referring to Chinese replicas and it has been one and a half years since I purchased it and my friend uses it in his garage and scanning average 5 vehicles daily basis. You won't have the agent specific functions such as shematic diagrams and access codes and latest updates for 308, 4007s etc, but to surive with a 406, that is more than enough I would say. :D
mattyf
Post by mattyf »
Hi all,
I just had the codes read.
He came up with;
1. Intermittent fault. Supply to sensors short circuit to earth
2. Intermittent fault accelerator pedal. signal to circuit to + or earth
3. Accelerator pedal to coherence with pedal signal
4. Intermittent diesel High pressure. Lack of pressure
5. Crank and camshaft syncopation signal speed to sudden
6. Heating circuit pre-heat
looks like its an earth problem ... where to start??? lol :roll:
also can someone please tell me how to solve or what 4-6 means? :oops:
paulb2004uk
Post by paulb2004uk »
This is possibly faulty glow plugs - If they need replacing don't go to Halfords - They are useless
Good luck
Paul
mattyf
Post by mattyf »
Thanks mate, Where would eryone else go? I normally get my parts from euoparts?
Dose anyone know about 4 & 5?
paulb2004uk
Got my Glow Plugs from EuroCarParts. Touch wood they have been ok
Paul.
mattyf
Post by mattyf »
Thanks mate, guess I will be making a trip to europarts.
Can anyone please tell me which area to look for a problem relating to "4. Intermittent diesel High pressure. Lack of pressure". :shock:
Many thanks
mattyf wrote:Can anyone please tell me which area to look for a problem relating to "4. Intermittent diesel High pressure. Lack of pressure". :shock:
Many thanks
Hopefully it's not the lift pump going fubar!
Teamy could be right there - your best bet would be to hook it up to a PP2000 & watch the live data to see what's happening. The codes alone don't really give you the full picture.
While it does look like you have a glow plug problem, it definitely won't be causing the limp problem, you may be better leaving that bit for now.
mattyf
Post by mattyf »
Cool, thank you ..... now to track someone down with a PP2000 .... hummm :wink:
paulb2004uk
I had error P1352 on my 2001 HDI90 - This did cause the car to go into Limp Mode - Replaced with Glow Plugs from Halfrauds.
Fault cleared immediatey. 87 miles later went back into Limp mode - Code P1352 - Removed glow plugs, all distorted.
Halfrauds replaced them with a new set - These lasted less than 500 miles. Each time they failed car went into Limp mode
Halfrauds gave a refund. Went to EuroCarParts for a set, 3000 miles ago and still working ok.
Hence earlier post not to use Halfords glow plugs
Paul
mattyf
Post by mattyf »
Yeah I've herd bad things about halfords parts!! Shame they used to be quite good! :roll:
mattyf
Post by mattyf »
Right .... quick update.
I managed to clear all of the electrical faults ..... there was few wires rubbing and caused them to short .. now sorted. :cheesy:
Yes the “Heating circuit pre-heat” fault was indeed glow plugs, so thanks to all!! Fires up a dream now! :twisted:
The only fault now is “Intermittent diesel High pressure. Lack of pressure” which is now turned into “Intermittent diesel pressure sensor” :roll: . Has anyone had this problem? Is this the sensor attached to the bottom of the fuel rail? If so, can it be cleaned or will I need to buy a new one??
