Intercooler Gone Bye Bye.... AGIAN ! !
- niz406
- Admin <BR>Turbo God
Well yes you guessed it, but not totally sure if its cooler or split hose, going to check it when I can and I'm more awake... ! !
If the cooler has gone AGAIN then its FMIC replacement time, there are some nice bar and plate jobbies from the states on ebay which might be the alternative to another plastic shoddy pug cooler ! ! !
Was going to do FMIC or concealed smaller cooler behind bumper under inner arch with direct feed from fog lamp shroud and stainless hard piping or..... FMIC with slightly modded bumper! and stainless hardpipes !
Until then I have the choice of a mitsubishi galant alloy cooler or RS500 cooler to use as a temporary measure!! The alloy galant one is much better looking and comes from a more powerful unit ! !
It's funny you should mention this because I was wondering about my intercooler.....
You see the HDi one is a plaggy unit and sometimes I get the feeling you can hear air escaping somewhere, thought about spraying Fairy Liquid mix on it to see if it bubbles ?
The HDi runs at about 1.0 bar, but don't know if the IC is a week point (as it seems to be on the petrols).
I know 2 lads that were running 200SX's a couple of years back down at the Pod (I am cool hehe) and they were getting decent gains from fitting a Volvo IC
not sure which model, but made a big difference in keeping charge temps more stable.
Your upgrade will not be a wasted effort, you should see gains JUST from a better IC, watch the lag though, your hard pipes will help with that.
- niz406
I've seen the HDi coolers.... they are functionally accaeptable to perform its duty, but physical construction and design leaves a lot to be desired... why must they insist on ABS construction for the items end caps... I'm sure some alloy end caps welded on or even crimped like the plastic ones would only be a few pennies more ! !
I've heard that about the sweeedish manufacturers
Saab and Volvo? have really good coolers... but again these are built on a budget!
Well I'm going to do the math before the upgrade because I want to make sure the IC is efficient enough without too much of a loss in pressure at the cold side once the charge has been cooled... there are some on ebay now with only a 0.2p.s.i pressure roll off @ 15 p.s.i
I've seen some nice IC spray kits too... but that would be overkill!
I'd rather go chargecooler I think !
- Davva2004
- Location: Stood beside my 406 with a sledgehammer, cursing everything French
Don't go chargecooler... lots of tests have proved conclusively that a chargecooler does not cool as efficiently as a decent front mount intercooler. Chargecoolers are fine while the water is cold - hence their fantastic rolling road reviews - but because water has such a massive thermal latency once it's warm after some hard road driving the piddly little rads they provide in the kit can't bring the water temp down so ACTs go high and stay high, till the water has chance to cool down overnight. Whereas a front mount IC has no thermal latency as it's always getting a fresh supply of cold cooling medium, i.e. fresh air.niz406 wrote:I'd rather go chargecooler I think !
A lad round here was showing me his Celica GT4 a couple of weeks ago, looked under the bonnet and there was a Toyota standard chargecooler.
I was quiet surprised, and indeed the Header tank for it, which sits a' top the engine
was very hot.
The charge cooler will only then limit the charge temps to probably 70 to 80 deg and no more, but constantly, whereas the FMIC has the ability to get rid of the heat almost completely if you back off a while, or fit a spray bar
- 1.8 8v
i got my fmic from "xspower" and its actually quite a nice item, as for solid pipes get busy and make up a 3d cad drawing, then pop over to http://alloyracingfabrications.com/ and he will bosh you up the pipes for a lot cheaper than you would get if using silicone and stainless.
quality guy and a quality item
1996 306cab with a few mods
http://www.hhtuning.co.uk do some very reasonably priced 'coolers for DIY applications.
