D9 semi-mux BSI & Dash problems
colin406exec
1.6 8v
Re: D9 semi-mux BSI & Dash problems
Post by colin406exec »
so been out tonight check mc45 both go to the same bolt and look fine and mc30 sits just at the top right of the acc pedal and looks fine also there is continuity between pin1 and earth mc30 next is check em45 and em45d didnt know they were there i realy need to find out what 90 is to
colin
Rather than just looking at them I thought the idea would be to undo, add a blob of dinitrol, waxoyl or just engine oil and do 'em up again.
I'm still wondering about 90xx myself, I have a feeling it doesn't mean anything other than the system is multiplex but, as I said, I don't know much about it. I had a quick look earlier but didn't see anything useful, or at least anything in a language I recognised :oops:
And today's word is "Manchester" :?
colin406exec
1.6 8v
no i did remove them clean and oil refit :cheesy: as i said i will look for em45 and em45d cheers for the help btw :D
colin
steve_earwig wrote: I have no idea what this "90--" is
90-- means the group of wires which begin with 90, as in VAN stuff.
For example, if you saw 62-- you'd want to be looking for the wires in question on the central locking diagram
What does it mean when it appears on the diagram that it refers to though?
colin406exec
1.6 8v
well traced em45 and 45d tonight there crimped in the loom just before the drivers seat all good there to so the problem is further back somewhere had all the tape off the loom from the dash out via the 3 plugs in footwell to drivers seat all wiring looks good fresh dry
colin
steve_earwig wrote:What does it mean when it appears on the diagram that it refers to though?
It means you need to find the right diagram with all the 90?? wires on it :lol:
That's like buying a craft knife and needing a craft knife to open the package...
colin406exec wrote:well traced em45 and 45d tonight there crimped in the loom just before the drivers seat all good there to
I take it you checked continuity to earth. This isn't looking pretty :(
What else doesn't work on the multiplex list?
steve_earwig wrote:Stuff on the comfort VAN:
BSI (check)
4000 : instrument panel central electronic module (check)
8220 : analogue module transponder (something to do with the immobiliser - receiver for the plip?)
8415 : compact disc player
8410 : radio
7215 : multifunction screen
8025 : air conditioning panel (if separate)
I must admit I'm getting pretty confused now, I don't think it's an earth fault, I think it's something on the mux and I have no idea what faults look like on them or how to test them.
Daft questions: does the car still have its original stereo and does the alarm work?
colin406exec
1.6 8v
BSI (check)
8220 : analogue module transponder (something to do with the immobiliser - receiver for the plip?) (remote never worked)
8415 : compact disc player (original multi changer and radio all work fine)
8410 : radio
7215 : multifunction screen (all work exept milage left in tank)
8025 : air conditioning panel (if separate) (ac needing regassed)
yeh its starting to look bad from here to, gonna download the puka wiring diagrams for my car and will have a good check at the weekend se what i find. just when i remember when i got the car i fitted my parrot bluetooth device from my old 406 d8 and when ifitted it it killed the dash when i plugged it in just when you mention radio and stuff
colin
How does this parrot thing work? I don't suppose there was any relationship to you trying to fit it & the car going mad :?
colin406exec
1.6 8v
that was at the start of the year and its not in the car because of this.
colin
Still Googling, I found some stuff on BBA:
http://www.bba-reman.com/forums/Topic33 ... nger+water
Not really what you have but it does show how a fault with one MUX unit will screw up the others. Worth pulling out the stereo to eliminate?
http://www.bba-reman.com/forums/Topic79 ... ent+lights
Note the 4th post down - I can't find anything else on the forum but.... Do you want to ask or shall I?
colin406exec
1.6 8v
ask away steve if your known on there you may get more responce than i do.
thanks
colin
ps i removed the radio lastnite to still no joy.
'tis done, yay verily forsooth - http://www.bba-reman.com/forums/Topic112792-1-1.aspx
I said I'd dispatch you over there to answer any questions, so you'd best sign up so you can subscribe to the thread & get email updates :wink:
Btw I hope you don't mind me lightly editing your post there :oops:
Any help? I didn't know about the shunt - on my (french :roll: ) diagrams it looks like fuse 8.
Interesting about the vin too - so there is a way of telling (and there was me trying to work it out by RPOs :oops: )
