pins,
roverv8
pins,
Post by roverv8 »
rear pads on a 406, do the pins that hold in the pads slide to the center of the car like most brake calipers?
dummysock
Re: pins,
Post by dummysock »
Hi
No I would say that they slide in from the centre of the car outwards. When they get corroded in, you need to give them quite a wallop with a nail punch and hammer.
I changed the pins and retaining springs on mine recently.
Re: pins,
You need to punch them inwards - see the howto for pictures: viewtopic.php?f=10&t=6840
dummysock
Re: pins,
Post by dummysock »
Hi again
They will only fit one way because one end of the pin is fatter than the other
roverv8
Re: pins,
Post by roverv8 »
R clips at thick end of pin so going on that they slide towards the center of vehicle away from wheel. :arrowl:
