Cambelt change: HDI 110 2.0
pgascoyne
Post by pgascoyne »
Hi Guys,
Just looking for some advice into changing a cam-belt for a W plate HDi 110 2.0 Saloon model.
I've currently got about 65K miles on my existing belt.
I've sourced a few places including eBay for kits including the pulleys and belt (some including water pump as well).
Any particular kits to go for?
According to the Haynes manual it mentions about requiring a specialist tool for measuring the tension of the belt once replaced.
If you don't have access to such a tool how did you go about getting the correct or approximately correct tension?
Is this the only stumbling aspect I need to worry about or are there any other issues I need to be aware of?
It's a shame there's isn't a KBA for it. (Knowledge Base Article)
Any thoughts or ideas much appreciated.
Paul Gascoyne aka Gazza
406 RED LX HDI 110 W Plate
omega
Re: Cambelt change: HDI 110 2.0
Post by omega »
this is the new way of doing cambelt jobs but the old way works just as well
jasper5
Post by jasper5 »
There is a how-to in the knowledge base.....it's for the 90hp but still the same......
viewtopic.php?f=10&t=8229
There is a good way of tensioning the belt in the how-to that I supplied :D
I use Gates belt kits.
pgascoyne
Post by pgascoyne »
Thanks for the replies guys.
I will digest that how to info and hopefully get it done as soon as possible providing the weather accommodates.
