4 x Nimrods 15"
benlowlew
4 x Nimrods 15"
Post by benlowlew »
Set of 4 x 15" Nimrods with tyres and bolts for sale. Will be off the car from Thursday. 2 x tyres will need replacing and the other 2 have plenty of life left in them. Comes complete with the correct bolts for them. Locking nuts as well. In good condition with only a tiny bit of corrosion but nothing bad at all. £100 the lot. Collection or pre arranged courier. Located just outside Wolverhampton.
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
Still available. Will be going on ebay soon!!
ally406
Re: 4 x Nimrods 15"
Post by ally406 »
I'd be interested in them. Are the tyres any good to you, as I don't need them?
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
I have no need for the tyres as I have the winter ones on now and then the car will be sold
ally406
Re: 4 x Nimrods 15"
Post by ally406 »
Can you tell me the weight and dimensions of one of the wheels please, and can you send your postcode?
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
The weight of one wheel with tyre is 16.3kg. The dimensions are 15" alloys with 195/65/15 tyres on. Postcode is WV6 7PW. Hope that helps.
ally406
Re: 4 x Nimrods 15"
Post by ally406 »
If I've worked that out correctly that's 64cm diameter, and should be 20cm width, can you confirm? What is your availability for a courier?
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
at the moment i am up in scotland for the next 2 weeks. back in wolves 17th so will check then if still interested
ally406
Re: 4 x Nimrods 15"
Post by ally406 »
Whereabouts? I'm near Glasgow. Are you here again?
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
unfortunately not with car as I came up on the train. back up in jan on the train again as its all paid for. currently near partick thistles ground!
benlowlew
Re: 4 x Nimrods 15"
Post by benlowlew »
Sold!!!
