New Owner - Fan/AirCon issues
hello,
i have inherited a 1996 406 sedan (was an abandoned vehicle) and if i can get it running then i can keep it.
I am comfortable with most things but the lack of power to the fans/air con has got me stuck.
I have power to all other things but no fan or air-con, fuses look ok but i have no manual to be completely sure so going on info ive found on the web (anyone got an owners manual in PDF ??)
Im an englishman living in tropical australia so a fan would be useful - aircon even more so ! and of course there is no dealer here - infact there is only one garage and hes no electrical expert, so any help gratefully recieved.
tia
tia
Re: New Owner - Fan/AirCon issues
under the glovebox is the main connector for the power. i would check here 1st its common for the connector start to melt
its directly under the fan behind the glovebox ..
it will probably look like this or worse . it could be this or something else. but its worth checking here 1st as its easiest
and using some 30amp connector blocks is what mine looks like now
As Gary said that connector block is a common failure, I have a chunky household connector block in mine.
If you still have problems take a trip to the breakers for a replacement, the resistor fitted to the motor would be the other thing to die. I changed mine for a motor from a 3 litre V6, it fixed the heater fault but strangely didn't give me V6 performance
Motor removal is a doddle, undo the 3 screws to drop the motor from it's housing and pull the brown block from the motor - job done in 2 minutes
Here in the UK they're easy enough to find in breakers yards, I paid £10 for a replacement, no idea how easy they are to find in Oz?
2003 2.2 HDI SE
2003 2.2 HDI SE
ah thanks guys - ill check in the morning, everything else looked fine but didnt check on that side if the car, a new motor would probably be available but im 2000km away from a major city, so may have to ring around and get it shipped up if thats the case
ok - the connector looks great - no fail there
cant check the motor - just waiting for a multimeter to arrive then i can do any checks - what do i need to look for to identify a faulty motor ?
the symptoms so far :-
no fan at all - the dash slider does nothing at all
press the a/c button and nothing - no indicator light
press the recirculate button - again nothing
all other electrics seem fine - but the skidding? indicator on the dash seems to be on now (wasnt yesterday and ive touched nothing other than look under the passenger dash for the fan connectors - related ???)
i wish i had a users manual - anyone have a pdf copy ??
currently 40degrees here so a fan / aircon is almost a necessesity
I'm not sure about the fan issue but with reference to the aircon system,has it got gas in it? The a/c will not work if there is low/no gas pressure in the system even the light will not illuminate,there is a pressure switch in the gas line that if it detects low/no pressure will hold off the system and will not let the compressor cut in.Thinking about it though i don't think the a/c will operate either if the fan doesn't run.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re manual for your car, there is a Haynes workshop manual torrent on the web that is easily downloadable.
Hi mate check fuse under bonnet
F3
25A
Acc +
ABS and traction control
Heres a complet list of fuses,
Dashboard Fuse panel:
FuseNumber - Rating - Functions
1 - 10A - Cigar Lighter
1A --- --- --- --- ---
2 - 5A - Radiator water level, diesel: Water in filter, instrument panel, Power steering
3 --- --- --- ---
4 - 5A - Front left/Right read sidelights, Rheostat lighting
5 - 10A - Headlight adjust control, headlight wash control, dipped beam warning light on dash
6 --- --- --- ---
7 - 20A - Caravan
8 --- SHUNT
9 - 5A - Front right/Left rear sidelights
10 - 30A - Seat Memory power
11 - 30A - Window lift mechanism
12 - 10A - Reversing Lights, Air Con
13 - 30A - Front right seat
14 - 30A - Front left seat
15 - 20A - Central Locking ECU, Fan relay, Bitron ECU, Seat memory ECU
16 --- --- --- --- ---
16A - 10A ? Radio
17 - 10A - Fascia lighting with daylight running light relay connector
18 - 5A - Rear fog lamp
19 - 5A - Passenger compartment switch illumination, fascia illumination
20 - 10A - Left dipped beam
21 - 10A - Compressor cutoff relay, compressors, pressure switch, daylight running lights, fan high speed relay, Air Con control
22 - 20A - Rear wiper, rear wiper timer
23 - 10A - Right dipped beam
24 - 30A - Front wiper control, front wiper timer, front wiper motor, heated screen timer
25 - 7.5A - Radio Memory, CD, Instrument panel analogue clock, coded anti-start, courtesy light
26 - 10A - Hazard warning light switch
27 - 30A - Front one-touch window lift
28 - 10A - Instrument panel, digital clock, rear view mirror control, front one-touch window lift, one-touch window lift ECU, seat memory ECU, Deadlocking ECU, relay for the re-supply to the window lift, sun roof, brake lights
29 - 30A - Front window lift, sun roof
30 - 15A - Front and rear lighting, glove compartment lighting, Lights on buzzer, hazard warning light switch, CD player
Engine Bay fuse panel
Fuse - Rating - Functions
FM1 - 50A - Anti-theft System
FM2 - 50A - Post ignition anti-theft system
FM3 - 50A - 30 fuse box supply
FM4 - 50A - Lighting Control
FM5 - 50A ? ABS
FM6 - 20A/40A - Fan 1
FM7 - 20A/40A - Fan 2
FM8 - 40A - Heated rear screen
The following is for the 2ltr Engine:
Fuse - Rating ? Functions
1 - 7.5A ? Injection ECU
2 --- --- --- --- ---
3 - 25A - ABS
4 - 20A - Engine Running
5 --- --- --- --- ---
6 - 20A - Horn
7 - 15A - Headlight washer timer
8 --- --- --- --- ---
9 - 10A - Lambda Sensor
10 - 10A - Fuel pump
11 --- --- --- --- ---
12 - 10A - Front left fog lamp
13 - 10A - Front right fog lamp
14 - 10A - Left main beam
15 - 10A - Right main beam
F3
25A
Acc +
3 --- --- --- ---
6 --- --- --- ---
7 - 20A - Caravan
8 --- SHUNT
16A - 10A ? Radio
FM5 - 50A ? ABS
3 - 25A - ABS
6 - 20A - Horn
I think there's only a D9 manual.D9406 wrote:Re manual for your car, there is a Haynes workshop manual torrent on the web that is easily downloadable.
Hold on a mo...
Just to get the bleedin' obvious out of the way, it is actually running now? None of this stuff'll work if the engine isn't running....if i can get it running...
Also the ignition switches on these can give problems, if you have no voltage to the fan see if wiggling the key around does anything.
I also have a fuse diagram for a 1996 that I lifted off of Passion406 (i.e. it's in French...) and this one says fuse 9 in the passenger fuse panel for climate (& interior light(s)), 21 for the compressor & control panel (and engine fan high speed & pressostat). If Lozz's don't do the business...
ive got manuals for D8s
but theres no way of, sending them, ~Need somethin to upload too,
Do you mean handbooks? How many?
yeah mate,steve_earwig wrote:Do you mean handbooks? How many?
there all work shop manuals,
there on one big file, full library of cars not just peugeots, most probs 30 books in each file.
ive been working on finding somewhere on the net to dump them but its to bigger file,
thanks guys,
the engine runs fine (just power steering issues to resolve- hole in cooling pipe - work in progress) but i drove the car to get it home so its running ok.
checked all fuses now w/ multimeter - and they are all good ( thanks for the fuse info)
the ignition is a possibility as i had to get the barrel off to get keys fitted - ill check.
ive managed to get a haynes manual - its missing the ref sections tho - but an owners manual would be good as haynes is a little too detailed and frankly overwhelming ! i need to grasp the basics first (what buttons do what/what lights mean what)
all other electricals work fine - only the fan/ac failing - how do i check for gas ?? or how can i test the fan motor ??
i have to say you guys are being very helpful - thanks heaps
craiggc wrote:hello,
tia
Craig, use the site search facilicity at the top right, type in heater blower not working or heater fan and you will get lots of info on the heater fan problem.
To test the motor, remove it and put current across the fan terminals from a battery being very careful to keep your hands away from the blades.
If you do any tests on the car the engine needs to be running to test the heater circuits. The heater fan only works when the engine is running.
hi there
i had a similar problem and found it to be a controller box underneath the dash the size of a cigarette packet cost about 70 pound unless you can get a 2nd hand one
only a suggestion as i not a mechanic
hope it helps
hope it helps
