Which laptop fault code reader
- 2.0 Turbo
Hi all
Need a fault code reader that will do a ford fiesta 1996, 406 hdi 110 2000, and xsara hdi 90 2002 seen some on ebay for 15-20 that i can plug into the laptop, does anyone have any recommendations i have seen this on.http://www.ebay.co.uk/itm/CAR-PC-DIAGNO ... 27c1c06929
- Bailes1992
Re: Which laptop fault code reader
I have the one above.
It's a good bit of kit!
He will email you a program called Proscan, and on the lead there is a serial number to activate the progam.
Does the job anyway
Does the job anyway
- 2.0 Turbo
would it be okd on both th 2002 and 2000 hdi's
- Bailes1992
Will be fine, they are all OBDII
OBD2 compliance wasn't mandatory for diesels until 2004, I suspect it won't work.Bailes1992 wrote:Will be fine, they are all OBDII
- 2.0 Turbo
My dad has lexia and peugeot planet but hes too far away to use it and want something that will read the sensors and fault codes etc but dont really want to fork out £100
I know it's still a bit of a jaunt, but you can always use mine if you want. (NN17)
- 2.0 Turbo
Thanks for the offer doggy i will definately let you know
Did you buy one ? Does it work on the 406, I have a 2000 406 and would like one to look at my injectors working...
PP2000 does, but they were a little over £100 last time I looked - search for 'Lexia 3'
got mine for a bit under £100 so magic... just finding faults i never knew about!
