heater blower
grasmere59
heater blower
Post by grasmere59 »
The heater blower did'nt start today and i've had the motor out and put it across a battery and it's o.k.,i'm getting 14.2 volts at the motor connection plug no matter where i set the fan speed but the motor wont run sitting in the footwell connected,it ran once and when i put the speed up to max it went at hyper speed and then just stopped.Would i be right in perhaps thinking it won't run at 14.2 volts and has some sort of over voltage protection? Why would i be getting a constant 14.2 volts at the motor all the time? ny info greatly appreciated as i'm supposed to be going away in it at the weekend and can't go without a blower. :(
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: heater blower
the d9 has a heater control module doesnt it ?
some1 was on about it other day . could it be that thats at fault ?
midsmike
Re: heater blower
Post by midsmike »
yeh i would say its that they always play up
grasmere59
Re: heater blower
Update: When you connect the plug to the blower the voltage dissapears,i disconnected the 2 big multipin plugs to check for overheating or corrosion but all o.k.,i reconnected the plugs and the fan came on laying in the footwell,it worked on demist and up to speed 3 but when i put it flat out it went mega fast and then stopped and wouldn't restart untill i disconnected the multiplugs and reconnected them again and then it restarted and ran in all speeds except flat out,in auto it seems to stay at a constant speed,should it speed up if you set the temp flat out?
Re: heater blower
i say replace the control module mate. fan is obviously working.
http://www.ebay.co.uk/itm/Peugeot-406-H ... 4aa62e8602
grasmere59
Re: heater blower
Just went round to my neighbours to see how his blower works (my old car) and went back to mine to make a comparison and mine is working now on all speeds!,put the fan back in the heater and it seems to work o.k. now although it vibrates on full speed but it might have always done that because i've never run the fan flat out before.I'm buggered if i know what was the problem. :?
grasmere59
Re: heater blower
Well it's packed up again,i've had the control/resistor module out and i'm getting live across the large black and red wires on the right (small plug) but live to a "body" earth on the large red wire on the large plug but nothing across the large red and black wire on that plug,any ideas? :?
