Heater Control Panel
the slide bar that speeds up my fan is a bit tempremental. when its around 3/4 across blowing fast if you touch it slightly it will shut the fan off and make clicking noise
do i need a new control panel ? i didnt have this problem in my old d8.
midsdaz
Re: Heater Control Panel
Post by midsdaz »
Mine does a similar thing cuts off but if
I move it just a slight bit more it fine again and if I move it quickly it dnt like to work
ye exact same mine. i like things to work properly. trying to source a new panel all day without aircon
seems not a lot of d8s had no aircon.
and i aint paying the £310 that the dealers are asking for it :shock: :lol:
Gary406 wrote:ye exact same mine. i like things to work properly. trying to source a new panel all day without aircon
ask these mate,
http://www.ebay.co.uk/sch/dksalvage/m.h ... 4340.l2562
ive had alot of parts off them,
There, very cheap and they didnt charge me for postage,
Theyve broke alot of peugeots so they might have one on shelf, worth a try,
failing that, other best place is Bury, (Star-breakers) theyre cheapest Breakers ive found so far,
midsdaz
Post by midsdaz »
changing the subject quickly im looking at a 2.1 excutive estate but the fuel pump has gone how easy is it to change the pumps ???
the fuel pumps on xud's are driven by the timing belt . that will give you an idea of how big a job it is :twisted:
you may as well change the whole timing belt kit and a new waterpump while fuel pump is being changed
midsdaz
Post by midsdaz »
I change the belts on every car I buy just so I no its done on the 2.1 they got more electrics ??? Is it a simple case of gettin another and putting it on or have I got to get it recoded and stuff
not 100% sure on that because ive never had a 2.1 or known any1 to change pump. but i cant see it needing coding on these old style lumps ..
make a new post about that mate sure sum1 will tell you or message jasper5 he will probably know for cert 8)
midsdaz
Post by midsdaz »
ok nice one
