Hi, I know this has been done to death but I'm
After a bit more info!
The heater blower doesn't work,
The motor is good, put across the battery to test it.
Bought a new heater blower resistor, still not working.
All connectors are looking good, took tham apart to check.
Now, I think it's the ignition as I remember I had trouble getting my key out one day and the heater didn't last much after that. I've wiggled everything death and still nothing
Wondered if anyone has had this and fixed/replaced the barrel to cure the problem.
I have a 2000 diesel hdi, any help or pointers would be much appreciated!
Ignition barrel/heater problem
Re: Ignition barrel/heater problem
I had the same problem , first key stuck and was a baarstard to get out
this was after all the usual blower probs . End result was new ignition
but as i did not have the code card that comes with the card it cost me
£170 for a complete set of locks
Problem solved.... Temp repair
A different way of doing the by-pass
I took a feed off the orange wire from the ignition to the red wire from the ignition ( one for the blower) that goes to the 40amp fuse in the fuse box under the steering wheel. Connected it before the 40amp fuse.
Just used a £3 inline fuse to join them
This will do me until I can afford a new barrel
Hope it helps someone, will try to upload a few pics if anyone is interested
Just one thing, what is the orange wire for normally?
