My new HDi...
widget
Re: My new HDi...
Post by widget »
hi
i keep getting over the past cpuple of years the engine managment light and keep having to reset it says throttle position 2
i was wondering after reading you changed your throttle sensor if this could cure my problem and if so are they easy to change and are they expensive
hope you can help
2002 2.0 hdi executive 110
Bailes1992
Re: My new HDi...
Post by Bailes1992 »
Bought a second hand one off ebay.
I will get a guide done today or tommorow for you... If I remember! :oops:
rwb
Re: My new HDi...
Post by rwb »
Exactly the same, and so did I.
I believe this is what you want: http://www.ebay.co.uk/itm/160678728866
It's easy to replace; it's held on by two 10mm bolts.
Bailes1992
Re: My new HDi...
Unclipping, clipping and adjusting the throttle cable is the bit thats hard to explain on here.
diagobd2
Re: My new HDi...
Post by diagobd2 »
The bodyworks abit tatty (much like my Focus), but the interiors MINT apart from a rip in the drivers bolster and a missing rear ashtray.
___________________________
obd2 diagnostic toolgm tech2
