heater only blows hot and aircon not working.110 hdi exec
hi folks,does anybody know what could be the cause of the fault i have please,my cabin blower will only blow hot and the aircon dont work either,they both packed up the same time.i have a 110 hdi exec estate y reg.i had the car about 3 years but its been off the road for 2 months cause clutch has gone,but im missing it so much im getting everything done starting with new clutch and dmf this week and i need all the help i can with it guys.thanks steve.
- lozz
Re: heater only blows hot and aircon not working.110 hdi exe
might be part no 3 faulty see picture
ok loz thanks i will try it,cheers.lozz wrote:might be part no 3 faulty see picture
- lozz
That might be not the fault mate,
but ithink its controled by a motor and cogs,
some one might know the correct answer,
I have a problem with my air con. I topped up the coolant , i can hear the compressor clicking in. The pipes into the bulkhead are cold, but i can feel no cold air. I dont know when the aircon last worked but figure all is well with cold pipes. So figure part no3 must be at fault... where is it situated?
hi peeps,ive found the fault on the heater problem it was the heater regulator thats fits onto the side of the heater casing behind the right hand side of the center console.£5 from scrap yard
thanks.
Was that part 3?
