is my turbo knackered?2.0 hdi
codgod
Post by codgod »
hi folks,im currently changing my dmf and im in the process of taking the car apart!.i took off the subframe today and i noticed oil all over the turbo and inside the turbo air pipe,quite a bit of oil was in the pipe is this normal or do i have a problem with the turbo.thanks steve.
Bailes1992
Re: is my turbo knackered?2.0 hdi
Post by Bailes1992 »
Sounds like you've popped a boost hose or have a boost leak. You get a little oil in the inlet manifold and boost pipes. Totally normal!
codgod
Post by codgod »
Bailes1992 wrote:Sounds like you've popped a boost hose or have a boost leak. You get a little oil in the inlet manifold and boost pipes. Totally normal!
hi bailes,thanks for your reply.whats a boost hose,does it need fixing?how do you fix it?have i lost power?
Bailes1992
Is it a HDi 110 or 90?
HDi 110 has an intercooler (Radiator between the turbo and engine) the HDi90 does not. The turbo is plumbed straight into the engine.
Boost hoses are the hoses that carry pressure between the turbo and engine.
codgod
Post by codgod »
Bailes1992 wrote:Is it a HDi 110 or 90?
it is a 110,what should i do?
