DMF
Re: DMF
From the very quick look ive had yours doesnt seem to have a DMF but someone with more time/experience should look and maybe confirm this or prove me wrong, while i was there, heres the info on your car
Vehicle characteristics
Vehicle family 406
Build code 08130 89 3 0148
Warranty Start Date 01/01/1990
BER e2*93/81*0188*00
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 406
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL LEVEL 3
ENGINE DW10ATED TURBO DIESEL
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE JACOMO VELVET "EZ"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BVM ML5T
ENGINE (TYPE) EW/DW
OTHER BADGE WITHOUT FULLER BADGE
BADGE GLX
TRIM LEVEL LEVEL 3
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 25X20
Fuel supply-Engine
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
SPEED SENSOR SIGNAL SENSOR HALL EFFECT
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
FUEL TANK INSULATION WITHOUT FUEL TANK INSULATION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF FUEL FEED CUT-OFF
RHEOSTAT RHEOSTAT
VEHICLE TECHNICAL DEPOLLUTION L3 VEHICLE TECHNICAL DEPOLLUTION
FAN 2 FANS , 2 RATES , IMPROVED
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 65
WHEEL STYLE ALLOY WHEEL OPALE
CLUTCH HYDRAULIC CLUTCH
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE GEARBOX ML
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 22
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE ELECTRONIC BRAKEFORCE DISTRIBUTION
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
POWER STEERING FLUID COOLING SYSTEM WITH COOLING
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
Body fittings
HORNS HORNS-HARMONY
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITH DEFLECTOR
SIDE MOULDINGS (TYPE) PROTECTOR WITH CHROME RING
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS L=50 + SIDE SILL
WHEEL EMBELLISHER (STYLE) SMALL DIAMETER HUB CAP
SIDE REPEATER INDICATORS SIDE FLASH-UNIT ASSEMBLY
INDICATORS WITHOUT SIGNALING LIGHTS
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
WASHER JET WINDSHIELD WASHER JET W/O DEFROST
EXT. REARVIEW MIRROR COMP. FUNCTION WITHOUT FULLER FUNCTION
EXHAUST TAILPIPE TRIM W/O EMBELLISHER
ENGINE BAY SOUNDPROOFING BONNET SOUND-PROOFING
WINDSCREEN GLASS (TYPE) NO HEATING WINDSCREEN
WINDSCREEN WIPER INTERMITT AUTO FR WIPER BLADE
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
BUMPER BUMPERS WITH EMBELLISHER
MUDFLAP WITHOUT MUDGUARD
LUGGAGE RACK MOUNTING WITH LUGGAGE CARRIER
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES DOOR MIRROR AND HANDLES BODY COLOUR
SUN ROOF FIXED ROOF
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) LAMINATED QUALITY 2
Interior fittings
ANTI-THEFT ALARM ELECTRICAL CONDITIONING
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
REAR SEAT ARMREST WITHOUT REAR ARMREST
INTERIOR ALARM ALARM FORGET LIGHTS
LOAD FLOOR MOULDING WITH LOAD FLOOR STRIP
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
LUGGAGE COVER WITH LUGGAGE COVER
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
AIR CONDITIONING WITH HEATER ASSISTED CONTROL
SPEED GRADUATIONS GRADUATION MPH
TACHOMETER REV COUNTER WITH NEEDLE
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
CONSOLE LONG CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
LOAD SPACE LIGHTING GLOVE-BOX LIGHTING
DASHBOARD EQUIPMENT DASHBOARD LARGE GLOVE BOX COVER, WOODEN TRIM
INTERFERENCE SUPPRESSION RADIO INTERFERENCE SUPPRESSOR
MISC. INT. LAMPS MAP READING LAMP
LOAD SPACE TRIM TRIM BOOT + RR TAILGAT FLAP
DOOR TRIM WOOD TYPE DECORATION
TACHOMETER (SIGNAL CONNECTION) REV COUNTER CALC
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
POLLEN FILTER WITH POLLEN FILTER
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT SUN VISOR SCREEN
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
INT. UPHOLSTERY ELEMENTS NOT WEAVED ROOF TRIM
FRONT SEAT ARMREST FITTED WITH ARMREST
EXTERIOR TEMP. INDICATOR EXT TEMP INDICATOR
COMPACT DISC MOUNTING COMPACT DISC
HANDBRAKE WARNING LAMP WITHOUT PARKING BREAK INDICATOR
REAR WINDOW LIFT ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVERS SIDE ELECTRIC WINDOW AUTO STOP
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT) WITHOUT REAR SHELF LOUDSPEAKER GRILLE
ON-BOARD COMPUTER NO COMPUTER
COURTESY LAMP FR+RE DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIV+PASS SIDE (W/O NOTICE)
RADIO RECEIVER PERFORMANCE 5 RDS RADIO
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARR+FR DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
RHEOSTAT RHEOSTAT
AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP
STORAGE (OTHERS) FRONT SEAT STORAGE + 2 BOXES IN BOOT
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LIGHTING TIMER ADJUSTABLE TIMER
INTERIOR PROTECTION WITHOUT INNER PROTECTION
SWITCH ELECTRONIC ANTI-THEFT KEY
COOLANT LEVEL WARNING LAMP WATER LEVEL WARNING
ANTIPOLLUTION MALFUNCTION WARNING LAMP WITHOUT ANTIPOLLUTION MALFUNCTION LED
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL,4 BRANCH
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
FIRST AID KIT WITHOUT FIRST AID BOX
TRAFFIC SIDE DRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 2 HF PLIP KEYS
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Vehicle family 406
General information
PRODUCT TYPE CAR
VEHICLE FAMILY 406
TRIM LEVEL LEVEL 3
TRANSMISSION BVM5
ENGINE (TYPE) EW/DW
BADGE GLX
TRIM LEVEL LEVEL 3
Fuel supply-Engine
FUEL DIESEL FUEL
ENGINE (TYPE) EW/DW
RHEOSTAT RHEOSTAT
TRANSMISSION BVM5
ABS WITH ABS BRAKES
Body fittings
HORNS HORNS-HARMONY
SUN ROOF FIXED ROOF
Interior fittings
CLOCK NUMERIC CLOCK
RHEOSTAT RHEOSTAT
Electrical
HORNS HORNS-HARMONY
Miscellaneous
Re: DMF
this is the clutch servicebox says is in your car
and the flywheel
and the flywheel
- plod
Re: DMF
Flywheel is 532H1 for that Vin number which didn't tell me a lot, but inputting my Vin in, also gives the same part number, thus you have a solid flywheel and have no DMF
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: DMF
It's probably worth double checking but it's looking like a safe bet.
Re: DMF
i just used the last 8 digits you posted and servicebox found it ok.
check the details of the first 8 lines of the info i posted, see if it matches what the car is
- 2.0 Turbo
Re: DMF
sorry to break in on this but i`m curious
i have 1998 2.1 estate , dont know what my clutch version is , does it say on servicebox ? ( i have printed the info off already )
what are the relative merits of solid versus Dmf ?
Replacement !
