just installed new heater matrix but water leaking from pipe
jason1987
Post by jason1987 »
i cant do them any tighter as im ruining the threads on the screws, and the rubber seals on the pipes look ok
midsmike
Re: just installed new heater matrix but water leaking from
Post by midsmike »
mate take the pipes back out of the matrix and get some instant gasket and put quite a lot around where the pipes go in and also around the rubber seals. Put it back together and leave it overnight. I had to do this to mine, even when i put new rubber seals and matrix it was leaking so i had to use instant gasket and it worked fine
jason1987
Post by jason1987 »
im gonna take it to garage in morning, so howcome its like this when it was ok before? gaskets look good as new i dont understand why its leaking
midsmike
Post by midsmike »
was it a peugeot part mine wasnt so thats why i think it leaked wiv mine
go to the Main stealer, and get some new seals,
there only pennies,
your s'posed to Throw the old seals away when you replace a Matrix,
midsmike
Post by midsmike »
lozz wrote:go to the Main stealer, and get some new seals,
there only pennies,
i did that i got new seals but it was still leaking
