odd knocking noise
Archangel
odd knocking noise
Post by Archangel »
when starting off , have a clunk noise front drivers side ,similar when backing off the throttle
Any ideas guys what it might be ?
Replacement !
jasper5
Re: odd knocking noise
Post by jasper5 »
Check your lower engine mounting and the right hand top mounting.
Archangel
Post by Archangel »
cheers Jasper , are they reasonably easy to change ?
Replacement !
jasper5
Post by jasper5 »
Archangel wrote:cheers Jasper , are they reasonably easy to change ?
Top mounting is fairly easy to change, lower mounting means removing the right hand driveshaft and taking off the mounting block....there is a lot of info on the forum about replacing these.
Archangel
Post by Archangel »
thanks for that jasper , would a physical check show if its worn or is it just the knocking noise that gives it away ?
is it worth doing all of them ?
Replacement !
Replace the lower mount sooner than later - will stop it tearing the expensive flexi-hose.
A pain to change the bottom one - I tried and failed miserably. All the others are easy. Do you get clunks when going over bumps? Could be anti-roll bar drop-links.
Archangel
Post by Archangel »
Captain Jack wrote:Replace the lower mount sooner than later - will stop it tearing the expensive flexi-hose.
no clunks
Replacement !
jonsowman
Post by jonsowman »
Is the bottom mount/flexi hose problem also an issue on the D8s?
midsdaz
Post by midsdaz »
Had the same thing wen I brought my 2.1 pull had a clunk and wen I let of ye throttle clunk turned out to be the wishbone the rubber had completely gone so 2 new wishbone and ball joints and it drives like a dream
