Injectors help
midsdaz
Injectors help
Post by midsdaz »
My 2.1 has a injector
Problem but I ent got the cash to buy new and seems toget a 2 nd hand one is a problem coz no one will split from engine I do have a set of 1.9 injectors how much difference is there between them coz my car is in desperate measures right bitch to start any help would be appreciated
Re: Injectors help
Sorry icarnt help much,
but from what ican see the 1.9 injectors look longer than the 2.1s
theres a few on ebay there guide says fits 2.1s :?
Re: Injectors help
midsdaz
Re: Injectors help
Post by midsdaz »
Yeh I looked at that one that's wat made me the question coz I got 2 sets of 1.9 rd injectors just need to no for sure befor I try it my cars driving like a pile of sh*t and really struggling to start
Re: Injectors help
perhaps the differnce is, within the lucas and the bosch,
if you look at the ones for Xantias they look the same as 2.1s and there a 1.9 xud lump.
midsdaz
Re: Injectors help
Post by midsdaz »
The 1.9 and 2.1 are the same engine Pretty much but I been told there are shims in the injector an the 2.1 has more coz of the fuel pressure is more how true that is I don't no I need to try get the part number for the injector and see if it matches its only the one injector I need the needle sensor has gone witch I been told causes it to do wat it does
midsmike
Re: Injectors help
Post by midsmike »
daz the injectors will fit but i dont think the pipes will
marty1979
Re: Injectors help
Post by marty1979 »
I believe the break pressures are different between the two.
Bailes1992
Re: Injectors help
Post by Bailes1992 »
1.9 lucas injectors will be fine.
midsdaz
Re: Injectors help
Post by midsdaz »
Didn't think the 1.9 come with Lucas unless On 306 I got a bosch pump and injectors off my 19
Re: Injectors help
did you keep everything including pipes off the 1.9
if you have why not just swap everything over, ?
youd obviously have to buy a cam belt kit tho, :(
viewtopic.php?f=1&t=7281&start=30
midsdaz
Re: Injectors help
Post by midsdaz »
Well got to do cambelt anyway but wouldn't it loose power coz of the pump ?
Re: Injectors help
Not sure on power diferences, id of thought it be the same tho,
ithink many just change them so they can run on Wvo,
have alook through the threads on here,
http://www.vegetableoildiesel.co.uk/for ... 400&page=1
midsdaz
Re: Injectors help
Post by midsdaz »
I wouldn't bother running cooking oil rather just put diesel in I'll look in to Bosch pump conversion if I can the injector
Bailes1992
Re: Injectors help
You can't just put a 406 1.9TD pump on a 2.1.
You would need the 1.9's engine bay loom + ECU along with the chips out of the keys.
You would be fine with a non ecu controlled pump out of a 306 1.9 though.
Or the simpler option, just find a 306 1.9TD with a lucas pump and get an injector off that.
