electric seat stuck
- Newbie
electric seat stuck
Hi guys a little help please my electric passenger seat is stuck all the way back after moving it while cleaning car.The fuse keeps blowing as soon as i press the button is there a way of manually moving the seat forward to see if something has jammed it.Thanks for any help
Re: electric seat stuck
check there is no coins in the runners or anything stuck in there. you should see this without moving it.
failing that the switch may be the problem
- Newbie
Just a bit more info the seat goes up/down tilts back/forward just wont go forward
definately sounds like theres a coin or something in the runner tracks. remove the side plastics and look inside the tracks.
i would check the inner one 1st since this is next to centre console were a coin would more than likely fall down .
- Newbie
Hey there @Gary406... how do I remove the plastic cover to look at the microswitch & wiring? Cheers
