Specific Towbar wiring kit for a '53 plate D9 2.0 HDi 110?
impster
Post by impster »
Hi, does anyone know if there's a specific 'plug and play' towbar wiring kit for a 53' plate (D9) Hdi 110 Saloon? Does anyone know the part number for this?
Failing that - would a universal kit be ok? If so, do I need relays etc or can I just splice in?
I'll be adding twin electrics - so a 12N and a 12S socket.
Many thanks.
Impster
grasmere59
Re: Specific Towbar wiring kit for a '53 plate D9 2.0 HDi 11
Post by grasmere59 »
I would'nt go down the specific wiring kit route as it'll cost a fortune,the 12n plug just needs feeds from the various lights so just splice in(no extra relay req'd) and the 12s plug needs a smartcom relay to power the fridge and charge the aux battery as i assume you will be towing a caravan?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
find one in a breakers yard, whats got or had a tow bar on,
just cut out the tow bar wiring out, Makes it alot easier than starting from scratch,
impster
Post by impster »
grasmere59 wrote:I would'nt go down the specific wiring kit route as it'll cost a fortune,the 12n plug just needs feeds from the various lights so just splice in(no extra relay req'd) and the 12s plug needs a smartcom relay to power the fridge and charge the aux battery as i assume you will be towing a caravan?
So, just to confirm, you reckon that I don't need any relays for the 12N side of things? Bear in mind my car's a '53 plate facelift model (D9).
If you can confirm that, then it's a piece of proverbial to splice in.
For the 12S i'll need a split charge relay as you suggest.
grasmere59
Mine is a late 2003 "53" Dec and it is just cut and spliced,it has only a 12n but my previous "52" plate had a smartcom for the 12s.
impster
Post by impster »
Great. Thanks for that Grasmere59. Just what I needed to know. 8)
Will get a towbar ordered tomorrow and a split charge relay, along with the 2 sockets.
Many thanks indeed.
