Hi guys - engine management light came up on the dash today as did the APF on the little screen.
Car seems to be running fun, although there did seem to be a pop when i started it up earlier off the exhaust but its only done that the once.
did have an issue with a leaky injector a while back, but thats been solved with a new washer.
any idea's?
Anti Pollution Fault - HDI90 2001
Re: Anti Pollution Fault - HDI90 2001
Could be just about anything. If it's just a glitch, the EML will clear itself after a few journeys. If it keeps coming back try to spot any patterns as an aid to diagosis. I would just wait & see.......
My Xsara HDi 90 used to make a very occasional pop when starting, but it didn't register as a fault, so I ignored it.
My hdi 110 does that now and again too.Doggy wrote:Could be just about anything. If it's just a glitch, the EML will clear itself after a few journeys. If it keeps coming back try to spot any patterns as an aid to diagosis. I would just wait & see.......
- 2.2 16v
Sorry Ive not replied back guys - internet went down!
Yep - seems to have miraculously cured itself, shall keep an eyeball on it!
- 2.0 Turbo
Mine did that when I tried to shorten/tighten the throttle cable. Seems it needs the dead spot before throttle pick-up.
- 2.2 16v
Went swimming today, same as before and it came on.
MFD said there was 80 miles in the tank. Fuelled up ran it for a couple of miles around town and few stop starts on the engine, and its cleared.
Using shell diesel same as before.
Any idea's? Could the fuel filter need changing? Not sure when it was last done - tbh the car needs a service!
