Hi guys,
Got a 2.2 HDI coupe recently and trying to sort out its problems. First thing was to remove the dpf, so cleared the fault codes with pp2000, read the ecu file with galletto, ran it through ecusafe and it said it had removed the dpf, wrote the new file back, unplugged the temp and pressure sensors and started it up. Seems fine, though the additive ecu is still saying that the additive level is low. Shouldn't the defap have disabled the additive ecu? I tried to follow a guide about resetting the additive counter but I didn't seem to have the same options as the guide. The multifunction display isn't complaining like it was before, just the fault codes on pp2000. pp2000 also says the additive fuel pump is defective, related? I don't need it to work!
I'm uncertain about how it's reading the additive ecu though....when I select the ecu it comes up with a message saying that it cannot recognise the ecu but do I want to carry on anyway. It still reads the fault codes etc but could this be why I don't seem to have the same options?
The car no longer seems to be in limp mode, the asr/esp isn't saying its defective anymore (which I think comes on in limp mode?) and I had it up to 3500rpm down my road (3000rpm max in limp mode I've heard?) and like I said it isn't coming up with an antipolution error or additive low message on the multifunction screen. Though I'm wondering if it's just because I've disconnected the pressure sensors....
Is there a definitive way to check whether the defap ecu changes have been successful?
The car definately has more power than it did before, though there is still a whistling noise coming from somewhere. When it was in limp mode I assumed it was the turbo wastegate being constantly open in order to stop the turbo pressurising. But now it doesn't appear to be in limp mode anymore and it's still happening. Any ideas what this could be?
Plenty of other faults to fix as well yet (central locking not working, fuel cap sensor broken and plenty of intermittent ecu communication faults) but one thing at a time I suppose! I haven't seen any other fault codes that may be related (as far as I'm aware).
Sorry for the essay but I'd be very grateful for any advice/ideas/suggestions!
Whistling noise? And how do you know if defap is successful?
Re: Whistling noise? And how do you know if defap is success
Hi & welcome to the forum.
Sounds like you have defapped it successfully.
I used to hear the hrw relay clicking in & out as you went on & off the throttle while it was doing a regen, it won't do that anymore if you've defappped it. A more certain way, (I think) is to look at the diagnostic parameters and additive ecu while the engine's running. You should get 752 deg. (IIRC) for both up & downstream exhaust temps & zero differential pressure once defapped.
You should be able to prove the original & defapped files are different. There may be more elegant ways to do this but I run cmd and use the old DOS file compare utility, (fc) to check. If you want, drop me a PM & I'll check them for you.
As far as the continuing error message is concerned I'm guessing yours is a fully-mux, (2002 on), car? I think you need to disbale the dpf in the BSI as well to stop this happening.
Regarding more power, I can sort you out a modified ecu file - if you're interested drop me a PM.
I'm off to Scotland on holiday in the morning and don't know if I'll be able to access the forum from where we're going, so don't think I'm ignoring you if you don't get a prompt answer.
Whistling noise - worth checking for boost leaks, (assuming this isn't just normal turbo whistle). Doesn't have a wastegate as such, it's a variable geometry turbo, if the boost's too high it adjusts to let some of the exhaust bypass the turbine wheel.Valandil wrote: The car definately has more power than it did before, though there is still a whistling noise coming from somewhere. When it was in limp mode I assumed it was the turbo wastegate being constantly open in order to stop the turbo pressurising. But now it doesn't appear to be in limp mode anymore and it's still happening. Any ideas what this could be?
I've done some more work since I posted this, I've got rid of the "whistle" I was talking about, though now it's making another high pitched whistle. Typical! I've only just got the car so I don't know if it's normal turbo noise or not, though it seems far too loud to me, it really is quite loud. Though maybe they just are, I wouldn't know!
I didn't realise they don't have wastegates, neat solution to the use vgt itself to do it. Strange though as that's exactly what it sounded like! I think the flexi section may be leaking slightly, wonder if it's coming from there.
Extra power is extremely tempting! Though I do a lot of motorway cruising so it's probably not worth it, and I'm not sure I like the idea of the turbo sitting at high pressure for hours on end.
Thanks for the help, Scotland's lovely, hope the weather holds out for you!
