Strange actions from my engine
midsdaz
Post by midsdaz »
Driving along bout 60 and the engine sounded like it had no oil in started knocking its bollox off dip clutch reved it up and it cleared come back 3 times only for a couple seconds pulled over checked I had no leaks etc nothing carried on with Jorney complete fine not a noise I was thinking diesel knock more than oil but what could cause this ?
grasmere59
Re: Strange actions from my engine
Post by grasmere59 »
Sounds to me like a sticking injector on a cylinder.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
midsdaz
Post by midsdaz »
U reckon I I took them out got them cleaned up it would cure it ?
Couid be timing is (Slightly)too advanced, i might be wrong tho,
diesel knock [′dē·zəl ‚näk]
(mechanical engineering)
A combustion knock caused when the delayed period of ignition is long so that a large quantity of atomized fuel accumulates in the combustion chamber; when combustion occurs, the sudden high pressure resulting from the accumulated fuel causes diesel knock.
marty1979
Post by marty1979 »
2.1? I had the same thing with mine, it's either air ingress or the needlelift sensor on the 1st injector is sticking or going bad, may even be the wiring or the plug.
midsdaz
Post by midsdaz »
I got other injector with the sensor so I'll fit that and see what happens but it ent happend again anyway
