Anyone on here worked on renaults?
Re: Anyone on here worked on renaults?
my exhaust
is something missing ?
heres the bolt that ihad trouble with
whilst iwas under the car inoticed an extra tank..
Fap related do you rekon, (small traingualar shape black plastic tank at side of fuel tank)
but in middle of the car the pipe that went too it as been looped, Heres hoping the Biatch as been de-fapped
didnt even know the lag had the fapp system on them, not that iwant one :lol:
jasper5
Post by jasper5 »
nice one jasper5
my exhaust is about 11 or 12 down on that list on the link,
looks like the Dpf as been flung 8)
heres the baffling part,
tyre fitter rekoned the wishbone was fubard, so thats off and been changed nowt wrong with it, fecking arsehole wait well isee him :frown:
when the car is parked on a slope or you go over a bump you get a Bo-ing sound from the supension, theres no clunks or bangs just this dull sound,
spring dont look old and shocker looks ok, (what do you rekon ? change the leg and take a gamble)
theres also play in the steering rack only midges tho and ihad to pull on the hub like a monkey to get the play,
iwonder if thats going to be a fail on the mot idont fancy the changing the rack job
dust cover on one of the track rod ends looks fubard but no play in it
jasper5 wrote:Thanks lozz, I'll give Star Breakers a ring tomorrow.
jasper5
ive just asked someone about a 206 box, and he rekons theres a breaker at Stacksteads that might have them in not sure on directions,
stacksteads is bacup /Newline way iirc
dont know where this yard is mind, didnt even know there was a pug breaker up there, might be worth looking into
There was also an old mill in burney that broke french cars, bought a few bits off them once, they had everything on shelves,
that was a few year back tho not sure if this mill is still there,
jasper5
Post by jasper5 »
jasper5
Cheers lozz, i'll look into it.
Regarding your Renault, is the top mount ok?
The play in the steering is fairly normal for Renault cars, it's in the inner rack ball joints.....
Track rod ends on the Renaults are a pain, i've changed dozens....4 this week!! They are only about a tenner from factors.
Might be worth taking the strut off and having a good look?
jasper5 wrote:
jasper5
Thanks again,
not sure on the strut tbh, theres no clunks or bangs or creaks its just this spring do-ing noise sounds like a weak spring,
il get another leg from a breaker,
the play in the rack with it being slight, do you think that will get me through mot?
trackrod end, iwill change it for what they cost, iwill get the blow torch on that me thinks if it dont budge
jasper5
Post by jasper5 »
The rack play should, at worst be an advisory, but anybody who sees a lot of these will know the play is fairly normal.
I have a technique for getting the track rod ends unscrewed, undo the big locking nut and spray lots of WD40 on the threads, bash the end of the track rod end and around the area where the big nut fastens on, this loosens the rust and frees them off nicely, put a 13mm spanner on the inner rod and unscrew the track rod end....count how many turns the old one took to remove it (usually 21 on these) and fit the new one the same number of turns.
cheers japer5
re: the iner track rod end do the iner ones have the plastic washers like the nissans?
im thinking these may be missing, ive noticed someones put new steering rack gaiters on it,
the play is next to nothing so im thinking they may have thrown the washers over there shoulder ..who evers been at em before,
ive had anosey around the net,
found this pic, looks like its the ball part that fails like drop links
after lowering the subframe on one side to get the wishbone out, it looks like ive fubard the bottom engine mount,
iwill let someone replace the inner track rods me thinks, before ibreak something else, :(
sorted the front spring issue. 8)
there was half inch of the spring missing :shock:
Rang the dealers up today for price on rear disks,
397 quid :shock:
theyve got the wheel bearings built in :(
anyone know where ican get some from a bit cheaper, ?
jasper5
Post by jasper5 »
lozz wrote:Rang the dealers up today for price on rear disks,
397 quid :shock:
I've changed loads of these, my supplier does these at a fraction of the dealer price.
PM your reg or give me the year and i'll get you a price.
