center rear seat belt
406pugturbo
Post by 406pugturbo »
Just wondering if its poss to replace my middle seat belt without replacing the whole back seat section? because mine appears to be missing.
I have to save up to be poor!
omega
Re: center rear seat belt
Post by omega »
what colour seat is it? as i might have a spare got a spare belt as well
dgt
Post by dgt »
Yes it is, I replaced all my belts. You need to take the bottom bench out and the parcel shelf. The plastic surround unclips and allows you to slide out the individual belt. The reel is held in with a 17mm bolt
Just for clarity...
406pugturbo
omega wrote:what colour seat is it? as i might have a spare got a spare belt as well
Its this colour lol plus my back seat has the belt built in it this is why i confused as to weather or not i can change it
have alook on the back of the seat, see if the back of it will come off,
if that part is seprable, you shouid be able to fit anew belt in there,
406pugturbo
lozz wrote:have alook on the back of the seat, see if the back of it will come off,
Ive had a look and it doesnt look like i can do anything! apart from cut the material which id rather not do for obvious reasons lol any suggestions very welcome.
406pugturbo
Nice one for that 8) i can have a crack at that today as long as it doesnt pee it down.
be very carefull taking out the bottom bolts that hold the fastener in. if its stiff use plenty wd40 and undo it a little then tighten back up and work the wd40 through. on my old d8 i managed to snap one of those bolts and it had to go in garage and have fuel tank removed to bolt a new plate behind it to safely secure the seat belt fastener back in place :cheesy:
