Lower suspension ball joint removal tool
cox377
Post by cox377 »
Hello guys,
I've googled the removal tool but it's showing a few different sizes. What's the exact tool for a 1998 406?
James
Re: Lower suspension ball joint removal tool
I was skeptical too, but having seen the demo, I'm now convinced, (thanks jasper5).
ColinCranwell
Post by ColinCranwell »
I think the hammer is a Splitter,
http://www.ebay.co.uk/itm/SEALEY-Peugeo ... 27c834fb86
This is a remover. I got one last year. Not professional quality but good enough for a DIY. I took off the hub assembly and took it down to a local garage, with the removal socket and they removed the old ball joint and fitted the new.
I had experience on a ZX Citreon so I new it was abeast of a job.
Regards,
Colin.
1996 1.9 TD Executive
250,000miles (August 2012)
cox377
Post by cox377 »
Is there a video of this demo :)
jasper5
Post by jasper5 »
ColinCranwell wrote:I think the hammer is a Splitter,
Regards,
Colin.
I don't know why they are listing this removal tool as being for a 407, the 407 is a completely different ball joint which doesnt need a removal tool.
jasper5
Post by jasper5 »
cox377 wrote:Is there a video of this demo :)
No, but it could be arranged :lol:
marco2002
Post by marco2002 »
Hi
Here's a video of how its done, came across this by accident a while ago. A couple of people watched it and said it would be easier if you take the brake disc and caliper off before doing it. hope this helps. Here's the link: http://www.youtube.com/watch?v=nrSCbMZLgKA
cox377
Post by cox377 »
Thanks for that video,
He makes it look easy!
I've ordered a new ball joint, but TBH by the time I've bought the tool it might be easier to wip the whole unit off off a donner car?
J
midsmike
Post by midsmike »
Don't use a second hand 1 and u don't need the tool I use a hammer and a blunt chisel to turn it
cox377
Post by cox377 »
Hello guys,
My motor failed the MOT on both front lower suspension ball joint boots. I assumed this was a case of changing both ball joints but the MOT guy told me they just replace the boots.
Has anyone done this, and on a 406?
James
cox377
Post by cox377 »
midsmike wrote:Don't use a second hand 1 and u don't need the tool I use a hammer and a blunt chisel to turn it
Did you take the unit off the car and put it in a vice for this?
omega
Post by omega »
cox377 wrote:Hello guys,
James
havnt done it but you should be able to get the boots from
www.balljointboots.co.uk
midsmike
Post by midsmike »
No I do it with it on the car just undo the nut but leave it in the wishbone until u loosen the ball joint then pop it out of the wishbone and un screw it
cox377
Post by cox377 »
Certainly sounds do-able
