State of play .
Had the head off nad while deciding whether or not to get another head discovered that the crankshaft pulley had sheared the woodruff key.Checked the head and valves ,camshaft,every thing ok.Got another camshaft pulley and head gasket and replaced everything.Set timing spot on,now its turning normally but still will not start.I've had the injectors out and cleaned them and replaced seals and replaced them in the right order.Any ideas anybody.
Hi Lads
I've tried easy start but as soon as i let go of the ignition key it just stops .There's fuel at the filter and have bled the injectors one at a time .My mate has a obd 11machine and the only fault that comes up is TPA,Can anyone recommend anybody near Gateshead with the full diagnostics kit
Hi Lozz
yep tried that.I've noticed on the display panel it's showing ECONOMY MODE would that have anything to do with it.As a byword i really appreciate all the assistance the lads on this site are giving me
norrie499 wrote:Hi Lozz
Hi Lozz
I'm not sure if i can do a BSI reset without my proper key so i've sent the key off to be repaired .As soon as i get it back i.ll try the resetCHEERS
