1.7 VVT frod zetec-s cambelt change - easy?
Been asked to 'help' change one for a family friend.
Anybody done one? Any snags / points to watch / should I pretend to be deaf?
Thanks, in anticipation.......
Re: 1.7 VVT frod zetec-s cambelt change - easy?
Erm What car is it :?
Year Model?
is it a Puma?
Sorry, yes it's a Puma, not sure of the year at the mo......
There not easy Mate,
you need a Special tool too, there abit like timing up arenault, on the Cams side,
you need":
camshaft setting bar-ford no 303 692 (21-246)
crankshaft timing pin-ford no 303 507 (21-210) details from A/d
2hrs & 50 mins book time,
Thanks lozz. Sounds tricky as you say.
Think I will do a lot more investigating before even thinking about trying.
Iwouid of put the proper instructions up for you but:
for some reason My pc wont let Me take a Snip of the Autodata :(
As of the Cam locking tools you Might be best off popping into Fords and see if they will Hire a set out,
jasper5
Post by jasper5 »
Be very careful doing this job, there is a routine that you have to follow or it can go horribly wrong :shock:
The crank pulley which carries the timing belt and the crank pulley for the aux belt DO NOT HAVE A KEYWAY!!!! Nor do the camshafts.
Along with using the crank timing pin, personally, I mark the teeth on the flywheel (accurately).You can get away without the timing pin by setting the cams and number 1 piston at TDC by removing number one plug and use a screwdriver to define nearest to TDC where the cam locking plate will fit into the cams at the rear.....but you MUST have marks on the flywheel.
I have the cam timing tool Eric, you can have mine if you like, just ask and i'll send it off to you.
You MUST set the tension with ALL the pulleys slack.....I can give you a full description if you like.
When are you doing it? I will be on holiday from tuesday for 2 weeks.
