This is a strange one but i've seen it on my mates keyboard and now mine.
The @ sign is now shift and 2
And the pound sign is non existant, wtf is going on anyone know?
lozz wrote:
go into control panel and click on regional and language options yours will be set on English (united states)
It sure was mate but even after changing it... It's the same.
gumby6371 wrote:
When I used to set up XP machines it always defaulted to US, I always change it to UK then delete the US options.
Think that's what i've done wrong, last week i got a new base unit but while installing xp i couldn't see the English uk option. Any idea if there's another way to change it? because going through control panel it asks to insert the xp disk and i ain't got one.
My XP knowledge is a bit rusty, is the language bar still active in the bottom right corner by the system tray? you can change it there. If it's not there I think you can right click on a blank spot nesr the system tray and re-open it using the toolbars tab (I think).
Other than that you can open it via control panel but like I said I'm a bit rusty and can't remember the exact path.
2003 2.2 HDI SE
gumby6371 wrote:My XP knowledge is a bit rusty, is the language bar still active in the bottom right corner by the system tray? you can change it there. If it's not there I think you can right click on a blank spot nesr the system tray and re-open it using the toolbars tab (I think).
Language bar is still there but it won't let me un tick English us... I might just run it for a few weeks to make sure nothing brakes down then instal win7... Problem is i don't have a recovery disk only a restore point which i think is no good without the disk?
gumby6371 wrote:have you added English UK to the list first ? You need to add it before removing the us option
Do you mean like this?
