2.0 HDI Xsara 90 Gearbox whine when slowing down
- 2.0 Turbo
Hi all i have a 2.0 HDI Xsara 90 that whines when slowing down through the gears this disappears when dipping the clutch it has always made the noise since i bought the car in november but wondered is this normal gears change fine. Also how do i change the gearbox oil is it difficult and what type of oil do i need.
Re: 2.0 HDI Xsara 90 Gearbox whine when slowing down
*Remove wheel arch liner,
*Gear oil grade 75w/80
* litres 1.85 - 2.0
* litres 1.85 - 2.0
- 2.0 Turbo
How do i check the level is it where you fill it up
filling it :You fill it until you see the Gear oil start to trickle out of the filling hole,
Checking it : if its at the correct level some will leak out when you take the bolt out if its at the correct level already,
(Check it/fill it with the car on level ground )
ihope that Makes sense,
Edit:
ive just noticed your looking for info on the Xsara
for somereason imiss read that the above is info for 406
the Xsaras are prone for gearbox whine, idoubt a change of oil will solve it but its worth a try
heres the diagram for a Xsara.
- 2.0 Turbo
i see some triple qx ep 75/90 oil is that any good and if not what would be the difference
adam03031980 wrote:i see some triple qx ep 75/90 oil is that any good and if not what would be the difference
You need 75w / 80 mate
its wont do the gearbox anygood in the long run putting in an incorrect grade:
When ihad Citroen Xsaras igot Gearbox oil for them from Wilkinsons, its very cheap there and goodquality oil
- 2.0 Turbo
Oh cool i will have a look when my wife take me xmas shopping fun not, sorry im on the wrong site just i got a 406 too and seem to get more sense on this site
adam03031980 wrote:Oh cool i will have a look when my wife take me xmas shopping fun not, sorry im on the wrong site just i got a 406 too and seem to get more sense on this site
If you need anymore info, just give us a shout.
Seriously tho on the xsara gearbox Whine,dont let it put you off the car if a change of oil dont cure it
ithink Many a Xsara owner justs learns to live with it,
- 2.0 Turbo
do you mind me asking what software gives you those diagrams is it something i can buy
adam03031980 wrote:do you mind me asking what software gives you those diagrams is it something i can buy
its Auto data,
you can download it off the Web,
to buy it ithink its about 300 notes or more at a guess
- 2.0 Turbo
- 2.0 Turbo
just out of interest there is a white cap on the gear box what is that covering
