Has anyone got any pictures or a run-through of how and what to look for to fix the airbag light issue on a 406 estate?
It's since I moved the seat right back to get at the clutch pedal.
Airbag light Grrrr.
- dukey406
- lozz
Re: Airbag light Grrrr.
its all guess work ithink mate,
what id do is just unplug one connector at a time, check that they click back in firm and can get a good connection.
if they dont -then cut the plug off and solder them together,
If you can find someone local with Planet, that will tell you which one is being a pain
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
