Basically, I have a 53 Plate 406 2.2 HDI SE and I'm in the market for an OBD-II Code Reader, to read and clear fault codes.
I've done a lot of searching/reading on the net and there is a lot of views out there that you'll be wasting your money unless you buy the Peugeot/Citroen system, namely Peugeot Planet 2000 / Lexia-3, as this is the only system that will correctly connect to the ECU and read the codes / diagnose / clear etc. Despite the legislation on OBD compliancy, Peugeot / Citroen have doen their own thing so that you can only use their kit.
Clearly, the cost of buying the real thing from Peugeot would be more than the value of my car but I have found numerous sites selling PP2000/Lexia-3 Clones (from China of all places!) and these retail around the £50-£100 mark but you need your own laptop running XP (which I do have).
My questions are simple, does anyone have one of these clones and do they work? Can I use any other OBD-II Reader? Do they work? If yes, which one is best to buy?
Many thanks in anticipation
