Timing belt - advice, please
jasper5
Re: Timing belt - advice, please
Post by jasper5 »
On the 110 you will find the crank locking hole behind the starter motor, it's easier to remove it to get to the hole, but a long round bar the same diameter will do the job.
There is a how-to for the timing belt in the KB......viewtopic.php?f=10&t=8229
drjonts
Post by drjonts »
Bless you Jasper!
Will have a lookie.
Jonty
drjonts
Post by drjonts »
Evening team,
Does this kit have everything (and more than) I need for timing my 110 HDi.
£49 - what do you think? Save the cash and use a few bolts of my own etc?
Jonty
Save the cash. An M8 x 30-ish set screw for the cam pulley and a choice of drill bits around 6 - 9 mm will do the crank end. (It's more convenient with the 'proper' tool, IIRC a length of 8 mm rod with roughly a 30 mm offset about 50 mm from one end, is easier to position betwixt starter motor & crankcase, but something straight will fit.
