Hi 406oc
Hi 406oc
Hi there thought I'd join up here and have a nose around the world of 406's. I'm a coupe owner and this site was recommended by a coupe club member.
2003 - 406 Coupe HDi SE Hyperion blue with Starfish.... defapped & 180 Remap
Re: Hi 406oc
Hi, and welcome on in,
Re: Hi 406oc
Welcome
Always good to share resources!
Re: Hi 406oc
Hi & welcome to the forum.
- highlander
- PowerFlow Shill
Re: Hi 406oc
Hi Allan! Welcome to the Volvo Owner's Club
I'm the opposite, I started off at this forum (having just bought a 1.8l 406 LX saloon) and then joined the Coupe Club for a look around when I was thinking of getting a Coupe. There's quite a few people here who are on both forums.
Unfortunately my old saloon got trashed the day I test-drove the Coupe by a white van man idiot who decided he wouldn't leave any of his insurance details, so that was a bit sour. Couldn't afford to fix it and it wouldn't really have been economical to do so anyway, so it got written off and sold to a local breaker's yard
Re: Hi 406oc
I too am on both.
Killed my V6 estate
Bought a coupe
Killed my V6 estate
Bought a coupe
406 Coupe S HDi
PP2000 clone interface
406 Coupe S HDi
Re: Hi 406oc
Thanks for the welcome guys !
Will have a good read of the forum very soon been way too busy with work. Looking for a solution to squealing brembos!
Also have a set of hoggars to sell. Is it ok to put an add on here? No problem if not they are just taking up too much garage space.
I'll check in again soon!
Re: Hi 406oc
only if you post the picsAllanAD03 wrote: Also have a set of hoggars to sell. Is it ok to put an add on here? No problem if not they are just taking up too much garage space.
Re: Hi 406oc
HAHA! of course! i'll just have to figure how to do it ........scotty73 wrote:only if you post the picsAllanAD03 wrote: Also have a set of hoggars to sell. Is it ok to put an add on here? No problem if not they are just taking up too much garage space.welcome to perverts corner.
Re: Hi 406oc
Hi Allan, i've been on both forums for several years now and it's friendly place regardless of Saloon/Estate/Coupe or even Volvo
Good luck with the brembo squeal as many people have tried! Mine are still fine luckily but i always use genuine front pads just incase!
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
Re: Hi 406oc
hi nutski, yes i tried exactly that with my last coupe, genuine discs & pads but still it squealed! i then changed the discs to drilled and grooved, which seemed to reduce the squeal quite a bit but was then left with a heavy humming when braking, presumably the pad passing over the grooves/holes??nutski wrote:Hi Allan, i've been on both forums for several years now and it's friendly place regardless of Saloon/Estate/Coupe or even Volvo![]()
Re: Hi 406oc
Yeah i have drilled and grooved discs on mine but with genuine Galfer pads, i can hear/feel when it runs over the grooves, might get normal discs next time!
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
Re: Hi 406oc
Welcome aboard Allan
Good to see u on here
about time you joined
Peugeot 406 2.2Hdi Coupe '02' Plate
Metallic Black(silver & black edition)
Manual, Rear Tints.
Manual, Rear Tints.
Re: Hi 406oc
hiya mate! glad to be here!Parm wrote:Welcome aboard AllanGood to see u on here
