digital climate control
- jameslxdt
my digital climate control is in farenheit rather than centigrade, does anyone know how to change it?
- jameslxdt
when you say left hand button what do you mean?
- jameslxdt
mines a d8
it has a different climate unit to that
Actually looks like this one never got answered!
James: In the infinitesimally slim possibility that you ain't worked it out yet (or for the advantage of anyone else who get this as a search result now this thread has been raised from the forum grave...), lever the display out and there's a little circular switch showing through a hole in the plastic on the right of it that you can rotate with a screwdriver. One click anticlockwise should change it to centigrade if memory serves.
- jameslxdt
yeah i still got the climate in farenheit which is annoying, that switch you talk of is on the side of the trip computer i think
- neildavies
Hi James, I found this, see if it makes sense to you. Maybe this wire's fallen out of the back. I could've sworn there's a switch on the back of the display on the D8, have you had a look?
if you want your temp reading in Fahrenheit
then attach an earth lead to terminal 8 on the top black 15 connector. My
car came with Fahrenheit as default, but when I pulled the earth lead out,
which is not shown in the Haynes, it changed reading to Centigrade!
2007 307cc Sport 2.0 HDi 136
- jameslxdt
are you sure this is on the climate control unit not the trip computer as the trip computer has 2 15 pin plugs, and in the top plug pin 8 is an earth, whereas the climate control has two large plugs one white one and one black one
ill have a look for the switch later today
- neildavies
