Diesel Knock / Chatter
- 2.0 Turbo
One of the guys at work said it sounded like my car had diesel knock on friday now i know its very chattery when cold but goes away when warm to me diesel knock is a lot louder has anyone had any experience with this mines the 2.0 hdi 90
Re: Diesel Knock / Chatter
I'd be surprised if you had a diesel that didn't sound knocky in this weather, mine sounds like a tractor when I first fire it up but calms down after a few minutes when it warms up a bit.
If it sounds normal once it's warm I wouldn't worry about it, it will idle high anyway with the cold start keeping the revs up to help warm things up.
Always worth leaving it ticking over for a few minutes in this weather before driving it.
2003 2.2 HDI SE
2003 2.2 HDI SE
+1
Injector noise is common, itl be this frosty weather no doubt,
- 2.0 Turbo
One thing i have noticed is that when started it will idle fine but after several minutes the revs drop as if its cutting out and it throws out black smoke then revs back to normal and it will do this consitently every 20 seconds or so until i drive off in it but once warm sits and idles fine
Sounds like it may be related to the cold start mechanism shutting down the fuelling to far then having to push extra fuel through on the anti stall causing the smoke, mine being an old school XUD it's controlled cogs and pulleys and bits of string not sure how it's controlled on a HDI but it probably involves that new fangled electrical magic.
Somebody from this century will be along to confirm or deny soon I'm sure.
If you've got the patience try holding the revs between 1100 and 1200 for a minute or so with your right foot.
2003 2.2 HDI SE
2003 2.2 HDI SE
Cutting out, Blacksmoke,
those couid be symptoms of a Blocked E.G.R valve,
give it a dose of wyns egr cleaner or simalar,
Some years ago, I owned an old 1980's Mercedes diesel.., a W123 240D. These engines are reputed to be
able to run on just about anything. I'd occasionally add some vegetable oil from Tescos.
What I really did notice was that with the veggie in.., the diesel clatter virtually disappeared. Not talking
about load of veg oil..., I never had more than about 25% veg in the tank.
I understand that modern common rail (?) diesels like the HDI are not quite so tolerant about what goes into the
tank...?
tank...?
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
- rwb
i.e., stuck open. Get it blankedlozz wrote:couid be symptoms of a Blocked E.G.R valve
I do get noticeably more "head noise" when it's cold. It takes more cranks to start these days (although I did have a cheap battery in two years ago), and cranking is definitely slower wen it's cold.
Nothing but diesel will do for the HDi I'm afraid. Once had a tankful of bio in mine and it was not happy; that caused the one occasion on which it nearly let me down.trufflehunt wrote:I understand that modern common rail (?) diesels like the HDI are not quite so tolerant about what goes into the
tank...?
There's nothing like the sound of an XUD on a cold morning
Don't you just love the sound of a xud on a cold morning?
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
Yep, mine sounds fantastic when it's freezing cold.
Still starts absolutely on the button though
- 2.0 Turbo
xuds sound nicer when running on old gearbox oil no clatter or knock just chug
madmadmax wrote:xuds sound nicer when running on old gearbox oil no clatter or knock just chug
- 2.0 Turbo
na its classed as an alternative fuel so it's fine just don't use more than 2,500l per year, never put power steering fluid in the tank did that once and got dipped the next day trying to explain that was hard.
theres one chap up here who runs his transit
on the oil out oiled filled radiators and transformer oil,
he rekons its better than pump diesel
