As a quick update before I update the blog:
Cleaned her out - well, I've made a good start.
Decided I wanted to turn the ignition to check the status of BOTH warning lights ''AIRBAG' flashing and ''abs fault'' that was visible via the central console plus, the EML which had been on the last couple of times the engine was turned.
I re-connected the drivers seat, all connections back in place with the seat.
Passenger airbag cables all clear from each other, live connection away from everything lol.
I turned the passenger air bag OFF via central console when first started this job: for added security.
I reconnected the battery negative terminal.
Then I lost all the balls I had previous to this.
I tried calling a friend to egg me on.
Then I ''whatsappd'' who gave me some of the courage I needed, plus I needed a wee so had to get on with it as had loads to pack away
I turned it on to the warning lights and backed away, the wipers came on and I didn't actually hear the ignition ticking, perhaps too ''lost in the moment'' to really care about such minute ticking when an air bag (or two) may have been just about to write me off
After a few seconds had passed, I turned the engine over.
Backed away again ''just in case'' but everything was going well.... UNTIL.... lol - there is no until. I just wanted to build suspense
Anyway, AIRBAG light still flashing at me, so I presume the seat belt pretens on the passenger side was perhaps not the cause of this after all.
ABS FAULT failed to appear and the EML also made a disappearing act
I must add, ALL I have done with regards the ABS is take the caliper off and spray AROUND the sensor, I did want to take out the sensor retaining bolt and clean up the mating faces of the abs sensor but as luck would have it, I couldn't get something that fitted in the darn thing yesterday.
SHOULD I continue to take out the ABS sensor, or just run the engine long enough, and perhaps rev next time in case it comes back on or ''while I am there'' just replace the stupid thing?
I guess, the last thing I want is to put caliper back on, wheel back on, off axle stands and then for it to say 'Ha! Just teasing ABS FAULT' comes back up
I am quite relieved the EML has disappeared, though disheartened the airbag light is still flashing its sexy ass off at me.
With regards the airbags, how does one remove the metal plate in the original connector boxes? IF at all possible I want to restore the use of this clip now..... I know I know, typical woman keep changing her bloody mind, it's my prerogative 'n all that polarva
Miss Pug 2001 - 2023.
