I'm looking for parts for a late 1.8i LFY engine to get my estate on the road again .
I'm particularly after an ignition coil pack, a bottom pulley, a set of injectors and a throttle body. Idealy, the throttle body wants to be off an earlier model as I prefer the alloy one. Many of these parts are also common to the 2.0i engine.
Thanks, Handyman
Wtd: 1.8i engine parts.
- Newbie
Re: Wtd: 1.8i engine parts.
Update: I've got my throttle valve & a set of reconditioned injectors, but I'm still looking for a bottom pulley and an ignition pack for the same engine, 1.8i LFY.
I'm also interested in any engine parts for the 2.0! 8V turbo engine, especially a turbo, a new Valeo clutch kit and a set of hydraulics. Wot U got? The clutch kit is the same for the 2.1 and 2.0 HDi engines.
Handyman
Handyman
- Newbie
handyman wrote:Update: I've got my throttle valve & a set of reconditioned injectors, but I'm still looking for a bottom pulley and an ignition pack for the same engine, 1.8i LFY.
Handyman
Did you get your ignition pack? I have a brand new Valeo one from the same model that I bought........ and then found it wasn't the problem and I couldn't return it. Having found the problem I now have a LOT of parts available!
