Central Locking & Airbag problems... Help!?
MrChips
Post by MrChips »
All this started with the airbag fault, wish I'd just left it!!
The central locking is not working in anyway now, not even with the key in the lock... Says in the handbook to see the main dealer... Guessing I will need a PP2000?
The airbag light is on and according to the auto electrician that came out to sort the immobiliser it is code 7 side module trigger.
Looking forward to your input.
grasmere59
Re: Central Locking & Airbag problems... Help!?
Post by grasmere59 »
I reckon the central locking is due to the immobiliser fault you had because the chap that did mine with the pp2000 had to do something to get my locking to work after he had cleared the immob fault.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
MrChips
Post by MrChips »
It was just the BSI reset that did the trick.
That's lucky! I always think the BSI reset procedure is one step from dancing round an oak tree at midnight with your draws off :shock: so it's good to hear it has some merit.
MrChips
Post by MrChips »
It wasn't just from the forum that the idea came, the Auto electrician talked me through it :D
