''Dead Lock''?
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
rustybullets wrote:From what I remember in the book, don't think you have to have an alarm to still have deadlocks.
Worth trying the key in the door method twice to check for deadlocks.
turn it once to lock it, let the key return but don't take it out of the lock,
then turn it again, and you should get another locking clunk to confirm the deadlock.
You are absolutely right :shock:
My car DOES have a deadlock facility, for some one reason or another it isn't working via the Fob.
I locked the car, window down. Turned the key as if to lock it again, a quieter but definite clunk was heard.
Tried the door handle from the inside and it's dead locked.
Alarm didn't go off - well, I don't have one so didn't expect that anyway... :lol:
Unlocked with the fob as normal.
Do I use this extra lock or not - that is the question and why isn't the fob working.....
Will wait for new key to arrive, swap it all over and then try again :D
Miss Pug 2001 - 2023.
Busman
Re: ''Dead Lock''?
Post by Busman »
Yep, all 3 of my 406s have had dead locks and no alarm. On the 52 plate they operate the first time you lock it, on the V reg and D8 you use the little button on the remote.
Does your red light come on when your little button is pressed?? :P :P
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
rustybullets
Re: ''Dead Lock''?
Post by rustybullets »
:cheesy:
May be just the microswitch in the fob not working. :?:
But at least you know you can deadlock it if needed now.
2.0 hdi 110 exec estate 2001
Honda accord type R 2002
Honda prelude 2.3i 4ws 4th gen 1992
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
Busman wrote:Yep, all 3 of my 406s have had dead locks and no alarm. On the 52 plate they operate the first time you lock it, on the V reg and D8 you use the little button on the remote.
Nope... Didn't work with the old button in, nor the new button...
rustybullets wrote::cheesy:
It is quite possible..
If anyone has one of these keys I'd like to see what the micro switch looks like...
markw
Re: ''Dead Lock''?
Post by markw »
Can only show what they look like fitted on the pcb. There are two types.
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
markw wrote:Can only show what they look like fitted on the pcb. There are two types.
Looks like mine is the second type *I think*?
crackpotterpig
Re: ''Dead Lock''?
Post by crackpotterpig »
Sonia have you got the pcb for yours? basically there are 2 different types for the Peugeots the infa red transmitter that were used on earlier models distinguished by a little clear plastic section that sticks out at the bottom of the fob and the radio transmitter ones which appears to be your type.
I have a spare key fob for a later 206 (2 button) that should work if you want it I had issues with my 406 when I first bought it but the passenger side central locking motor/solenoid is faulty so I haven't bothered!!
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
crackpotterpig wrote:Sonia have you got the pcb for yours? basically there are 2 different types for the Peugeots the infa red transmitter that were used on earlier models distinguished by a little clear plastic section that sticks out at the bottom of the fob and the radio transmitter ones which appears to be your type.
What does the PCB stand for? :oops:
I don't know what type Lozz has, think he was going to send me his? Is your key exactly the same as mine? Cheers :D
markw
Re: ''Dead Lock''?
Post by markw »
Printed Circuit Board.
The little green thing in your pic.
crackpotterpig
Re: ''Dead Lock''?
printed circuit board the part with the 2 buttons on that locates over the battery.
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
markw wrote:Printed Circuit Board.
If it's in my picture then yeah, yeah I do :lol:
crackpotterpig wrote:printed circuit board the part with the 2 buttons on that locates over the battery.
See above, lol
crackpotterpig
Re: ''Dead Lock''?
just use the key far easier :)
Sonia406
Re: ''Dead Lock''?
Post by Sonia406 »
crackpotterpig wrote:just use the key far easier :)
Yeah.. definitely!
It does work via key - came in handy at the petrol station the other day, so why not! :D
