Got my trolley jack, all the tools I need and the day to myself - what can go wrong....
Bloody buggering wheel bearings, thats what.
They have separated, so I cannot remove the back part without a claw-type hub puller to get behind it. I got the new backplate on, fitted the brakes and got it all sorted but the bearing is not coming off with brute force so I have had to take it all back off again and wait for a puller.
Also, the bloody sodding handbrake cable. They were completely jammed into the backplate. I managed to hammer one out with a 7mm socket through the backplate and pushing the handbrake cable out the back, after hammering my hand a few times. On the second side, my hammer glanced off the socket and smashed the ABS sensor to pieces..
I have now simply put my tools away before I throw something ' hammer shaped ' across the horizon.
Oh well, tomorrow is a new day, lets hope I have better luck. I can borrow a puller from friendly garage close by but still need to free the handbrake cable from the backplate - an overnight soak in WD40 should help.
MOT on Friday - car should pass with a decent handbrake but will fail it now with a fooked ABS sensor..
Tonight I will be drowning my sorrows with cider and chocolate...
