Hi Folks,
I have the fault code of "P1802 - Level 2 Drivers Airbag Igniter Open Circuit"
Any Ideas what is causing this and how to fix it?
Fault code P1802
Re: Fault code P1802
Bad connection to drivers airbag.
I'd think you wouid have to inspect the wiring connector to it and make sure its getting a good connection.
Obviously-remove battery lead first before working on airbags.
Someone else might have a better idea..
The connector under the seat is the usual suspect, remove battery, unplug it and give the connector a good clean, usually works for me.
2003 2.2 HDI SE
2003 2.2 HDI SE
Thanks, I have looked at the connections and all fine there. Took it to the garage as need to get this sorted for the MOT and they think it is the Clock spring... Any ideas on this??
