Hybrid project....
ashleyt33
Hybrid project....
Post by ashleyt33 »
I am working on my 206 gti project and am going to be using quite a few 406 parts.
I will be running the 406 SRI turbo engine, but am trying to make it a little different.
Apart from the complications.....does anybody know if it is possible to mate the 2.2 bottom end with the SRI Turbo head?
coupe v6, iced up ;)
niz406
Admin <BR>Turbo God
Post by niz406 »
Why do a 406 turbo engine when you can just buy a turbo kit for your current motor.... your talking 220hp easily and they have everything you need: here
Niz406
ashleyt33
Post by ashleyt33 »
niz406 wrote:Why do a 406 turbo engine when you can just buy a turbo kit for your current motor.... your talking 220hp easily and they have everything you need: here
Cost really more than anything. I was talking to them a while ago about the 406 v6 turbo conversion and it was quite expensive.
And I cannot see there being 2 many other 2.2 turbo 206's in the uk (if it is possible to bolt the turbo head to the 2.2 XE block)
niz406
Admin <BR>Turbo God
Post by niz406 »
As far as I am aware you can only use XU blocks with XU Heads and XE heads with XE blocks... but someone correct me if I'm wrong??
Niz406
jameslxdt
Post by jameslxdt »
you are correct niz, only xu is compatable with xu and so on, if malachy appears i think he will also confirm this
