10mls of oil can look alot when it's been sprayed around by traveling along at 60+
![Cheesy Grin :cheesy:](./images/smilies/icon_cheesygrin.gif)
Re: painting plastic trim, I did it years ago using vinyl coat 40 & it works a treat just can't remember how durable it is
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Which 2.0 petrol litre engine? Mind you, the mounting is the same for both http://peugeot406coupe.nl/catalogus/D9G/1/18A25A.HTM Looks like you've picked up 17 but you probably needed 1Sonia406 wrote:The engine mount I need to replace is drivers side, on the top.
it's a 2.0 petrol engine
I think you're right (thanks for the link!)steve_earwig wrote:Which 2.0 petrol litre engine? Mind you, the mounting is the same for both http://peugeot406coupe.nl/catalogus/D9G/1/18A25A.HTM Looks like you've picked up 17 but you probably needed 1Sonia406 wrote:The engine mount I need to replace is drivers side, on the top.
Ha ha......lozz wrote:That type of mount is always hidden..they screw into the innerwing
You won't see them with the dogbone in place.
There's a special tool for removing them, hammer and chizzel gets them off better tho
Ares wrote:Sonia what about that rust there just above the grill.
do something
do something
dirtydirtydiesel wrote:Ares wrote:Sonia what about that rust there just above the grill.
do somethingMy thoughts too, if left untreated for too much longer there'll be nowt to attach to grill to
( look at the state of those mounting holes )
