Hand brake shoes
Madmas
Hand brake shoes
Post by Madmas »
Hi
Can anyone tell me which shoes I need. On trawling the net I have been offered 180mm, 185mm and 200+mm diameter.
If it shows on servicebox, VIN is VF38ERHZF8158xxxx.
Also have clunking when driving on not too rough roads, likely causes please!..thanks
Ian
Re: Hand brake shoes
That looks something like front disk sizes (160 something, 183 and 205mm) but what you're actually after are handbrake shoes, of which there are but two - ones for drum brakes only and ones for drums-in-disks.
Yours is a... estate HDi 110, so it'll be drums-in-disks. The Mintex catalogue (as good as any) says Diameter [mm]: 180; Width [mm]: 30
Oh, I forgot the clunking - probably drop links - viewtopic.php?f=10&t=17207&hilit=drop+links
Madmas
Post by Madmas »
Hi, thanks for the replies..
Are the links handed ? or one size fits all ?
thanks
Ian
The links are the same either side, one size fits, umm, everything but the earliest 406s (i.e. 1996) - you want the ones like farmerpug's fitting in the how to.
